Date/Time: Thu, 13 Mar 2025 02:30:24 +0000
DOM Window scale is larger during replay.
View Count: 450
[2022-06-05 02:05:52]
Colby Stoker - Posts: 31
I am finally getting a strong enough knowledge of the platform, I find it quite amazing in it's power. I have tried to reset the chart scale for the DOM, but when I replay a chart, in certain circumstances, the DOM window shows one tick across the entire window. If I restart the DOM then it fixes it, but I have to rebuild the DOM and relink to my charts.
https://www.sierrachart.com/image.php?Image=1654394372171.png
[2022-06-05 07:04:24]
Try performing the Auto Scale functionality in this case:
The Chart DOM Scale: Auto Scale the Chart DOM
[2022-06-05 07:09:10]
This worked perfectly, thank you.
