Date/Time: Fri, 07 Feb 2025 15:12:17 +0000
color bar based on open and close within prior bar range
View Count: 741
[2022-06-04 16:14:49] |
User36082 - Posts: 4 |
Is there a study that will color a bar or identify bars based on the open and close of the current bar being within the prior bar's range?
[2022-06-05 12:32:12] |
Sawtooth - Posts: 4173 |
Use the Color Bar Based On Alert Condition study, with this formula on its Alerts tab:=AND(MAX(O,C)<H[-1],MIN(O,C)>L[-1]) Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart |
[2022-06-05 15:18:01] |
Thank you for the information at post #2. Here is the documentation for Color Bar Based on Alert Condition: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-05 15:18:33
