Date/Time: Fri, 04 Apr 2025 21:07:02 +0000
Scale on some charts goes wide when opening Sierra Chart
View Count: 465
[2022-06-04 15:08:15] |
BenjaminR - Posts: 172 |
When I open Sierra Chart, the scale on some charts have to be adjusted. Link below with an example. It would be a lot better if I didn't have to take the time to go through & adjust each of the charts every time I open the software. I'm not sure why it does this, or how to prevent it. Please advise. https://www.sierrachart.com/image.php?Image=1654355184399.png |
[2022-06-04 16:09:19] |
Tony - Posts: 564 |
If you are referring to price scale, than you can set a specific 'Constant Range' for each chart. (Under Chart Settings -> Scale)
[2022-06-06 10:49:29] |
What is the Scale Range set to for the chart?: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph There are other unknowns, which makes it hard for us to know what is precisely happening. However, do as suggested use a Constant Range Scale: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
