Date/Time: Thu, 26 Nov 2026 16:59:34 +0000
How do i view E mini futures on sierra chat?
View Count: 1155
| [2022-06-04 02:19:24] |
| User488171 - Posts: 24 |
Hello I am subscribed to all the necessary data package but i cannot view E mini futures on my sierra chat. Could you please provide me with a correct ticker name or way i can input that data so i can view futures chart. I am able to view SPX and Spy. Thank You
| [2022-06-06 14:35:04] |
Use the Find Symbol window to find the specific item you are looking for. You can either select File >> Find Symbol or from the Chart Settings window, where you enter the Symbol name, once you have that field selected there is a button for Select, which will bring up the Find Symbol window. Note that we can not give you the exact syntax since order routing services use different formats and names for symbols. Therefore, you really need to use the Find Symbol window where we have done the conversion for you based on your Current Selected Service Settings. For more information, refer to the following: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-13 14:36:59] |
How do remove this annoying error message from my chart. I clicked to Rollover and the error still stays on the chart. Please walk me through how i can fix this?
| Attachment Deleted. |
| [2022-06-13 16:35:30] |
When you get that rollover window, you need to select the specific contract to rollover to in the New Symbol pulldown. Note that by default it shows the same contract, so you would typically want to select the next one down in the list. If you just select OK, you are not changing the symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
