Date/Time: Fri, 14 Mar 2025 07:31:15 +0000
THRESHOLD RATIO
View Count: 457
[2022-06-03 23:00:22]
User696421 - Posts: 4
MY NUMBER BARS THRESHOLD IS SET AT 3,3,3 AND WHEN THE IMBALANCE SHOWS ITS NOT AT A 3 TO 1 RATIO CONSISTANTLY. PLEASE HELP
[2022-06-06 14:29:37]
John - SC Support - Posts: 38653
Which Coloring Method are you using? Keep in mind that a setting of Based on AskVol/BidVol Percentage will give you percentages relative to 100, so you will not get a 300% comparison.
Also, given that you have the Threshold set to 3,3,3, then you would need to set the Range 0 Colors to the same as the background, otherwise those colors are going to be used for anything between 0 and 3.
