Date/Time: Fri, 14 Mar 2025 04:43:23 +0000
New to Rithmic - Aggregated/Non-Aggregated question
View Count: 2729
[2022-06-03 22:44:21]
Tony - Posts: 553
Just started Rithmic service, wonder if I should use Aggregated data or Non-Aggregated?
I guess my concerns are, whether Aggregated data would affect the accuracy of .scid files and Non-Aggregated would affect performance?
Also, for trading CME futures (ES, MES), does location matter? (Chicago, Mumbai, Seoul, Singapore, etc.)
P.S. My broker uses Ironbeam as the clearing firm, I would assume they could support Teton, if they are able to set up Teton Routing for my Sierra Chart Username, does that mean I don't need Rithmic at all?
Date Time Of Last Edit: 2022-06-04 18:56:18
[2022-06-06 14:16:50]
John - SC Support - Posts: 38653
You would have to ask Rithmic about the difference in Aggregated v. Non-Aggregated data.
There is going to be some latency differences in location, but you would have to see how that affects your overall trading. Keep in mind the CME Group is in Chicago.
Yes, this is correct - if you can use the Teton Order Routing Service, then you would not need Rithmic at all, and you would save money overall, as the Teton Order Routing Service does not have any fees, so you would not pay any order routing fees.
