Date/Time: Thu, 17 Sep 2026 03:50:07 +0000
show DOM for mini, but trade micro - cross trade
View Count: 1681
[2022-06-03 21:42:14]
Radu Sirbu - Posts: 40
Hi guys, is there a way I can set my chart & DOM with ESM22 symbol, but when I click on the DOM for entering the market, the order to go to the micro contract?
Basically I want to analyze the volume and the DOM for ES and to trade the MES (micro) and not opening another Trading DOM window for MES.
Thanks,
[2022-06-04 16:50:12]
Thanks user GC5150!
I read the instructions, but I still have some additional questions regarding the settings (see the screenshot attached).
In the "symbol" field I have ESM22. In the "Trade and Current Quote Symbol" I chose MESM22. For "Use as trade symbol only" I chose "YES", but for the fields below I'm not sure what to fill in.
In the field "Real Time price multiplier" should I change it to 0.1 or leave it 1?
In the field "Currency value per tick" should I manually change it to 1.25 if I will trade Micros or should I leave it $12.5.
Thanks in advance!
imagesetttings cross-trade ES-MES.png / V - Attached On 2022-06-04 16:46:29 UTC - Size: 45.51 KB - 424 views
[2022-06-04 19:24:36]
Thank you very much for the clarification!
