Date/Time: Tue, 26 Nov 2024 09:51:29 +0000
Problem with
View Count: 1280
[2014-05-01 17:31:12] |
User51760 - Posts: 108 |
Hello Sierra Chart Support Team, on costomizing the Chart Shortcut Menu (Global Settings > Customize Shortcut Menu) I am not able to remove the Menu Items Study Settings and Delete and Download Data. Furthermore the position of the Menue Item Study Settings in the Chart Shortcut Menu is not consistent with its position in customization. Please refer to a short screenmovie (51 sec) under https://dl.dropboxusercontent.com/u/5931986/Customizing%20Chart%20Shortcut%20Menu.wmv Is there a way to remove the stubborn Items or giving them the right position? What am I doing wrong? Thank you for your support, Best, Chris Sierra Chart V. 1130 |
[2014-05-01 18:23:00] |
You cannot remove those commands. Also the Study Settings item will be at the bottom of the displayed menu. All of this is by design. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-01 21:41:52] |
Hello Sierra Chart Support Team, thank you for your reply and explanation. Good to know Sierra Chart is behaving properly. Best, Chris |
