Date/Time: Tue, 26 Nov 2024 08:41:34 +0000
Daily Loss Limit met
View Count: 750
[2022-06-03 14:00:12]
Ju17 - Posts: 39
I traded 3 MES and get stopped. Sierra charts chart stats shown - 754 usd but statistic and r trader shown -79 usd . I cant trade anymore because my desk is locked. Please tell me what i have to do to enlock and more important what do to envoid that this problem happens again. Thank you very much for your efforts in advance.
Symbol ES and trade and current quote is MES
Date Time Of Last Edit: 2022-06-03 14:02:37
[2022-06-03 14:03:31]
If you are referring to the Daily Profit/Loss value, refer to:
Help With Daily Profit/Loss Value
Are using Global Profit Loss Management?
[2023-11-30 15:05:17]
Ju17 - Posts: 39
i have a 80 tick stop in MNQ but the trade get closed always after 16 tick. I have a global loss management but its 1000 usd and can not be the reason. Please help, i can not trade MNQ anymore.
[2023-11-30 17:39:45]
John - SC Support - Posts: 36286
What is happening that is preventing you from trading?
If the "Global Profit/Loss Management" kicked in to stop your trading, then refer to the following:
Global Profit/Loss Management: Lock Trading >> Lock After Positions Flattened
If this is something else, then we would need to know what it is.
In terms of your position being closed early, you would need to look through the "Trade Activity Log" to find the order that was sent that did this, and then look at the "OrderActionSource" to determine the origin of that order. Refer to the following:
Trade Activity Log Analysis: Determining the Origin of a New/Modified Order
[2023-12-07 15:11:56]
Ju17 - Posts: 39
not the daily loss limit. when i trade MNQ , sometimes the trade get closed after 16 ticks but i have a stop of 80 ticks. this is not every time the case, only every second time. I trade MNQ on NQ chart, just in case this will be a helpful information.
[2023-12-07 16:44:04]
You would need to look at your Trade Activity Log and see why the trade closed out when you did not expect it to. The information is in the "OrderActionSource" field. Refer to the following:
[2023-12-07 17:23:00]
Ju17 - Posts: 39
Rithmic Direct - DTC (Filled), Order Type is Market, Internal Order ID 6539, Fill ExecutionService ID 1191299
[2023-12-07 18:28:15]
That is the Order Fill, now find the market order that was put in and find the source of that order.
[2023-12-08 13:47:28]
Ju17 - Posts: 39
How do I do that?
[2023-12-08 15:02:00]
Sierra_Chart Engineering - Posts: 17179
Refer to:
