Date/Time: Fri, 14 Mar 2025 07:38:46 +0000
Charts are not updating.
View Count: 385
[2022-06-03 12:52:51] |
User716514 - Posts: 1 |
Hi There, I have checked that my services and data subscriptions for CME are all active. However, my futures charts for MNQ (NAS100) are not updating. Can you please confirm what the issue is? Thank you |
[2022-06-03 13:33:17] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
