Date/Time: Thu, 13 Mar 2025 22:11:11 +0000
Teton - Server side bracket orders -
View Count: 845
[2022-06-03 12:28:24]
TGK4711 - Posts: 17
Just to clarify this.
Your clearly pointed out in Sierra Chart Teton Futures Order Routing that "Server-side Bracket orders are always enabled with this service regardless of the Use Server Side Bracket Orders setting."
In General Trade Settings "Use Server Side OCO/Bracket Orders" = YES
In my "Trade Orders" window I get under "LastOrderActionSource" the following output:
"... Client text: Attached order. Parent: 505. Tag: 1C_S02_T4.twconfig | Attached Order | Client side bracket order | Client side OCO order. Text: Attached order ..."
So no matter what is logged in "Trade Orders" - Server side brackets orders are always on with Teton?
Thanks!
[2022-06-03 13:11:55]
We are not seeing the entire text. But it would make sense to see this text, in one of the order update messages because on the server side the order is client-side managed at the server level: Client side bracket order |
You can definitely trust that a bracket order, as long as it is using native order types, that it is managed on the server. What are the order types involved?
Date Time Of Last Edit: 2022-06-03 13:12:15
[2022-06-03 15:15:15]
TGK4711 - Posts: 17
Target: Lmt
Stop: Stop
Entry Time  Last Activity Time  Symbol  Status  Internal Order ID  Order Type  Buy/Sell  Open/Close  Order Quantity  Price  Price 2  Filled Quantity  Average Fill Price  Parent Internal Order ID  Time in Force  Good Till DateTime  Service Order ID  Trade Account  Link ID  OCO ID  LastOrderActionSource  Client Order ID  Exchange Order ID  Text Tag  TrailOrderOffset  TrailOrderStepAmount
2022-06-03 14:13:42.688  2022-06-03 14:13:42.810  MESM22_FUT_CME  Open  505  Limit  Buy  Open  1  4116.00  0.00  0  0.00  0  Day    155340  xxx  505  0  Teton CME Order Routing (Order update). Info: CME (New). Text: Parent order. Tag: 1C_S02_T4.twconfig  505.33724  6834304637297  1C_S02_T4.twconfig  0.00  0.00
2022-06-03 14:13:42.688  2022-06-03 14:13:42.810  MESM22_FUT_CME  Pending Child-Server  506  Limit  Sell  Close  0  4117.00  0.00  0  0.00  505  Day    155341  xxx  0  506  Teton CME Order Routing (Order update). Info: Order from DTC client #8729. Sierra Chart. xxx.xxx.xxx.xxx | Client text: Attached order. Parent: 505. Tag: 1C_S02_T4.twconfig | Attached Order | Client side bracket order | Client side OCO order. Text: Attached order. Parent: 505. Tag: 1C_S02_T4.twconfig  506.29684    1C_S02_T4.twconfig  0.00  0.00
2022-06-03 14:13:42.688  2022-06-03 14:13:42.810  MESM22_FUT_CME  Pending Child-Server  507  Stop  Sell  Close  0  4115.50  0.00  0  0.00  505  Day    155342  xxx  0  506  Teton CME Order Routing (Order update). Info: Order from DTC client #8729. Sierra Chart. xxx.xxx.xxx.xxx | Client text: Attached order. Parent: 505. Tag: 1C_S02_T4.twconfig | Attached Order | Client side bracket order | Client side OCO order. Text: Attached order. Parent: 505. Tag: 1C_S02_T4.twconfig  507.44845    1C_S02_T4.twconfig  0.00  0.00
Does this helps?
Date Time Of Last Edit: 2022-06-03 15:24:36
[2022-06-03 15:22:45]
TGK4711 - Posts: 17
Otherwise please tell me what exactly I have to provide to you. :-)
Thanks!
[2022-06-03 17:16:07]
Since this text is from an order update:
It is showing that on the server, it is being managed as a client-side order. It is a server managed order.
You can also tell by the status:
[2022-06-04 09:43:22]
TGK4711 - Posts: 17
Thank you for the information. I appreciate your software and support. Go on!
