Date/Time: Tue, 26 Nov 2024 11:47:04 +0000
нет звукового сигнала при дисконекте интернета
View Count: 1222
[2014-05-01 16:50:51] |
User72575 - Posts: 7 |
нет звукового сигнала при дисконекте интернета . как настроить?
[2014-05-01 20:44:08] |
Do you want the sound alert when using CTS or Rithmic?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-01 20:44:25
[2014-05-04 15:57:30] |
I wanted to Rithmic? |
[2014-05-05 21:25:00] |
The functionality that Sierra Chart has to provide an alert when connected or losing the connection to the data server will not work properly with Rithmic.
[2014-05-06 05:55:31] |
This is not good. and how to configure it to dorman? I have a demo of dorman on sierra |
[2014-05-06 09:26:48] |
Are you referring to the CTS T4 trading platform service documented here: http://www.sierrachart.com/index.php?l=doc/CTS_T4.php If so, this is supported by Sierra Chart. Follow the instructions on the page linked to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
