Date/Time: Fri, 14 Mar 2025 10:15:45 +0000
Volume Profile of Different Time Periods On Same Chart
View Count: 466
[2022-06-03 01:01:33] |
User494557 - Posts: 3 |
Hi, If I have a chart that goes back say 1 month, is it possible to have one VP for the entire 1 month period shown at the end of the chart, and then a separate VP for each week, all on the same chart? This would save me from loading up separate charts for each VP. |
[2022-06-03 13:51:59] |
John - SC Support - Posts: 38653 |
Yes, you can do this. You just use two instance of the VbP study, one for the 1 month at end profile and one for the weekly profiles. Refer to the following for how to setup the single profile at the end of the chart: Volume By Price Study: Single Volume Profiles At End of Chart And refer to the following example for a 1 month profile: Volume By Price Study: Current Month Volume Profile at End of Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
