Date/Time: Thu, 13 Mar 2025 23:45:39 +0000
Lock down study by usernames
View Count: 643
[2022-06-02 23:20:16] |
User355030 - Posts: 163 |
Where am I able to upload my chartbook, .dll, etc and provide access by username and revoke it when needed? I've done it on here before, just can't seem to find it.
[2022-06-03 10:43:13] |
This is here: https://www.sierrachart.com/UserControlPanel.php?page=ManageCustomStudiesDLLUsers We may need to set up for you a Custom Studies DLL Name for you to do this. We are not sure what is set up on your account already. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-03 10:43:37
[2022-06-03 11:09:13] |
You’re right it says we need to set it up, how can we do this?
[2022-06-03 14:49:15] |
John - SC Support - Posts: 38653 |
Refer to the information here: Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users As noted in there, one of the first steps is to request the DLL name be added to our distribution system through an Account Support Ticket. You can access the Account Support Tickets here: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
