Date/Time: Fri, 14 Mar 2025 10:14:27 +0000
change username
View Count: 478
[2022-06-02 20:06:57] |
User356540 - Posts: 5 |
hello, i am french and not speake english.j'ai besoin de changer mon username: dorman trading ilda5vod23 et de changer mon numéro de compte de trading dans tout sierra chart: 43664 je viens de changer de compte sur votre conseil pour stage 5 trading avec dorman trading. merci par avance de me configurer mon nouveau nom et numéro de compte je suis bloqué je n'y arrive pas. Jean-Luc |
[2022-06-02 21:28:28] |
John - SC Support - Posts: 38653 |
From Google Translate: Hello,
i am french and not speake english.i need to change my username: dorman trading ilda5vod23 and change my trading account number in any sierra chart: 43664 I just changed my account on your advice for stage 5 trading with dorman trading. thank you in advance for configuring my new name and account number I'm blocked I can't do it. Jean-Luc We are sorry, but we are not understanding what you need for us to do. If you have an account with Stage 5 and Dorman, then you are hopefully using the Teton Order Routing Service. If this is the case, then you would just need to give Stage 5 your Sierra Chart Account Name and they will make the connection between your Sierra Chart account and your trading account. You would just have to go through the Setup Instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions -- Otherwise, if you are using a different order routing service, then we would need to know what service you are using so we can get you the proper directions. -- Also, the Sierra Chart account from which you have posted is expired. We did not find any other accounts associated with the same email as the account you have posted from. If this is the account that you will be using then please activate the account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
