Date/Time: Fri, 14 Mar 2025 07:39:59 +0000
How do I change text to make all the numbers on my DOM appear bigger?
View Count: 462
[2022-06-02 15:56:25]
CJBuckets - Posts: 20
Problem is shown in image below
imageDOM.png / V - Attached On 2022-06-02 15:56:13 UTC - Size: 272.17 KB - 115 views
[2022-06-02 20:41:49]
John - SC Support - Posts: 38653
Refer to the following setting:
Graphics Settings: Chart Text - (current font name)
Just make sure you change the appropriate setting based on whether the chart is using its own graphics settings or the global graphics settings.
