Date/Time: Fri, 14 Mar 2025 07:37:00 +0000
DOM price ladder show every second Price by mistake
View Count: 425
[2022-06-02 15:44:42] |
User238799 - Posts: 15 |
I must have changed a setting by mistake, and i can't find out how to make it undo. Since then, the DOM Price ladder does not show all the prices anymore,... just all the second prices. Please see the screenshots. Can you tell me how to fix it, so that the DOM displays all the price? Thanks very much!
![]() ![]() Attachment Deleted. |
[2022-06-02 20:36:24] |
John - SC Support - Posts: 38653 |
Refer to the following setting: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-02 21:25:41] |
Thanks very much for the Help! But sadly the scale increment was already set to 0.00. I have changed it to other values and back to 0 but it did not solve the problem. What else can i do? Thanks very much!
[2022-06-02 21:35:53] |
Since your scaling is set to Constant Range, then what you are seeing is just the system drawing the labels such that they will not overlap. If you change the size of the scale, then you should get a different set of prices displaying - depending on which way you scale - expand or compress.
