Date/Time: Sun, 04 Oct 2026 06:10:33 +0000
using denali data feed for live level 2 data and rithmic simultaneously for execution
View Count: 1933
[2022-06-02 07:51:01]
User13051990 - Posts: 26
Good Morining,
I use the denali data feed for live CME data. At the same time, I would now like to trade debt capital. To do this, I would have to log into a Rithmic account. This should only be used to execute the trades. Live data should not be received.
How is this to be implemented? Using a second instance of sierra chart?
Greetings
Date Time Of Last Edit: 2022-06-02 08:13:23
[2022-06-02 14:21:06]
John - SC Support - Posts: 48095
Sierra Chart is specifically setup to have you get the data from us and trade with your trading account. Refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
But, if what you are asking is how to have a connection to your live trading and another connection to the new Rithmic account, then for this you would want to have a second installation of Sierra Chart. As long as both installations are on the same computer then there are no additional costs. Then one installation would be connected to your personal trading account the other to the Rithmic connection.
Refer to the following for instructions on creating a second installation:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
And then refer to the following to setup a connection to Rithmic:
Rithmic Trading Platform Service: Setup Instructions
When you have this all done, you will be getting the Denali data for the Full CME Group to both installations.
