Date/Time: Fri, 02 Oct 2026 10:26:07 +0000
Dom on the chart/small numbers
View Count: 1142
[2022-06-01 22:40:10]
MetaTradingVR - Posts: 33
I'm going in circles trying to figure this out. How can I adjust the font size on the DOM when it's connected to a chart? It's always squished into each other. It's perfectly fine when it's connected to a separate trading window. Pics attached.
imageScreenshot 2022-06-01 152944.jpg / V - Attached On 2022-06-01 22:34:36 UTC - Size: 51.4 KB - 264 views
imageScreenshot 2022-06-01 152925.jpg / V - Attached On 2022-06-01 22:34:40 UTC - Size: 27.86 KB - 339 views
[2022-06-02 13:45:42]
The font size can be adjusted. This is explained here:
Graphics Settings: Fonts
And you can also adjust the scale:
The Chart DOM Scale
