Date/Time: Thu, 13 Mar 2025 02:38:40 +0000
candlesticks are too wide
View Count: 1375
[2022-06-01 19:43:52] |
winner - Posts: 4 |
Hi there, I really need to have the candlestick size back to normal. Please take a look at the screenshot. Thanks |
[2022-06-01 21:48:39] |
John - SC Support - Posts: 38621 |
The first thing to do is to change the bar spacing so you can see more candles in the window, which will shrink the size of each candle. Refer to the following for information on how to do this: Working With Charts: Changing Bar Spacing Once you have that worked out, then if you still do not like the amount of space that is taken up by each bar, then you can change that by changing the Graphics Settings >> Other >> Candlestick Width %. Refer to the following: Graphics Settings: Candlestick Width % (Global Settings >> Graphics Settings >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
