Date/Time: Fri, 14 Mar 2025 07:38:46 +0000
historical chart and data
View Count: 531
[2022-06-01 16:10:16] |
User449884 - Posts: 167 |
Where can i find instructions on how to go back years on the S&P charts? even possibly to inception
[2022-06-01 17:32:14] |
John - SC Support - Posts: 38653 |
Refer to the following: Continuous Futures Contract Charts And also the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-01 18:58:54] |
thank you, even after following all the instructions, i cant get anything earlier than 2016
[2022-06-01 21:34:35] |
Tell us the exact symbol you are referring to.
[2022-06-02 12:43:30] |
The current contract is ESM2.CME, but id like to have a historical chart of the S&P from the inception.
[2022-06-02 12:55:34] |
Ok the problem is that you cannot use Rithmic to get long-term Continuous Futures Contract charts because the symbols have a single digit year. You need to use another installation of Sierra Chart set to the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-02 12:55:48
[2022-06-02 15:51:37] |
Thank you, that worked perfecty. My next question is this: is there a way to have separating lines when contracts expiration via a study or setting ? |
[2022-06-02 20:38:03] |
Refer to the following option: Chart Menu: Show Rollover Dates (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-03 12:37:56] |
thanks
