Date/Time: Fri, 14 Mar 2025 04:46:32 +0000
Trade window for chart
View Count: 558
[2022-06-01 15:06:37]
DblArrow - Posts: 10
I am running sierra on a second monitor attached to my laptop via hdmi. In the display settings I will often move the second monitor (with sierra) from one location to another, i.e. from the top to the left side, etc. If I open a trade window for a particular chart, NOT ATTACHED, then move the monitor location, and try to open the trade window, it will not open in the current location. I must move the monitor back to the location that I opened the trade window and move it or close it. Any thoughts? Thanks.
[2022-06-02 11:03:56]
Sierra_Chart Engineering - Posts: 18778
You need to reset its position:
Chart Menu: Reset Child Window (Chart menu)
[2022-06-02 12:59:54]
user_xyz - Posts: 453
Thought this problem was similar but resetting child window didn't work. I have multiple chartbooks with Detached DOMS positioning all the same across chartbooks. When I switch from one chartbook to another the Detached DOM keeps resizing to half screen. I grab a corner, resize to full vertical length but when I switch to chartbooks the DOM keeps reverting to half screen. How can I reposition so it will stay used to not do this... Thanks!
[2022-06-02 14:21:51]
This is some operating system level behavior. You will need to figure that out on your side. We have no idea.
