Date/Time: Thu, 13 Mar 2025 02:57:56 +0000
Cannot connect to data feed
View Count: 345
[2022-06-01 13:57:57]
User717744 - Posts: 4
My account cannot connect to the data feed.
I am using real time CQG data from AMP futures.
I already renewed my sierracharts usage time two weeks ago and I did not change my service package.
Thank you
[2022-06-01 16:39:34]
John - SC Support - Posts: 38621
There are two changes that have occurred recently that are impacting you.
1) We changed our packages such that you need to be on Package 10 or higher in order to be able to make any external connections with Sierra Chart. This means that packages 3 and 5 are for testing/training with our Delayed Exchange Data Feed.
We have set your account to evaluate package 12 for 30 days, which will give you the access you need for this. Therefore, there is nothing you need to do, in relation to this, at this moment. Just be sure you change your package before the 30 days is finished.
2) With version 2394, we are no longer allowing CQG data for the CME Group or EUREX into Sierra Chart. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394
Therefore, you either need to change the software version you are running - or you need to get data from us for the CME Group and/or EUREX.
Refer to the following to roll back to a previous version you were running:
Software Download: Simple Rollback Procedure
And refer to the Setup Instructions for the Denali Exchange Data Feed for the CME Group data here:
