Date/Time: Thu, 13 Mar 2025 03:54:20 +0000
Using TickMill as my broker with CQG - no realtime data
View Count: 806
[2022-06-01 11:05:12]
cstandfast - Posts: 13
Hi SC Support
I have recently moved from CQG desktop to SC within my brokerage account with Tickmill in the UK.
I have setup and paid for the service pack 10 and can connect to my CQG account using the web API.
The issue is that I have discovered that realtime data isn't available anymore as I am using SC version 2394 on windows 10.
How do I resolve this?
If it can't be resolved, then how do I arrange to be refunded?
Kind Regards
-- Colin
[2022-06-01 12:34:16]
Hi SC
I have seen within SC that there is an option to install a previous version of the product -- would this be a viable workaround if they support realtime data connectivity with CQG API?
If so, which version for windows 10 should I install to replace ver 2394 64-bit?
It looks like it maybe the solution in the short term until Tickmill (my UK futures broker) work something out with you guys.
Best,
-- Colin
[2022-06-01 14:15:32]
Yes.
2393 or earlier:
Software Download: Software Rollback Procedure
Date Time Of Last Edit: 2022-06-01 14:15:52
[2022-06-01 14:29:38]
Thanks SC Support for confirming the workaround.
I will look into 2393.
Couple more minor questions:
1. Do you have any UK brokers that you work with? If so, is there a webpage somewhere of supported brokers?
2. Whats the differnce between SC exchange data and Denali?
Hopefully Tickmill (who I am very happy with) will come up with a new way to support SC that will also use Teton as well.
Regards,
-- Colin
[2022-06-01 15:50:44]
Hi SC Support
I have installed ver 2393 and I can confirm that real time futures data using CQG from my broker is now working.
Thanks for all your help.
Regards
-- Colin
