Date/Time: Thu, 13 Mar 2025 01:10:28 +0000
how did connect CME trading datafeed
View Count: 468
[2022-06-01 10:17:21] |
User359273 - Posts: 26 |
https://www.sierrachart.com/image.php?Image=1654077935207.png above image is required the SC data - All service because when i use CQG webapi, nothing showing, i will paste another one about CQG Webapi 1:how to saving data to a file is correct |
[2022-06-01 14:13:59] |
1. Follow CQG instructions here: CQG Trading Platform Service: Setup Instructions 2. Translate symbols following instructions here: Edit Menu: Edit >> Translate Symbols To Current Service 3. Activate exchanges here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-01 14:14:43
