Date/Time: Thu, 13 Mar 2025 02:38:40 +0000
log message sent for computer clock being off
View Count: 419
[2022-06-01 00:34:41] |
whats1thingnow - Posts: 407 |
log message title: Notice: Your computer's clock is off by 32 seconds. For help with this, press the 'Send for Analysis' button. | 2022-05-31 17:51:48.965 "Local computer UTC time and Server UTC time difference: 32 seconds. | 2022-05-31 18:08:14.090 Notice: Your computer's clock is off by 32 seconds. For help with this, press the 'Send for Analysis' button. | 2022-05-31 18:08:14.090" thanks for letting me know how to fix this |
[2022-06-01 15:12:25] |
John - SC Support - Posts: 38621 |
You can ignore that message if you like. 32 seconds is not going to create any issues. But, if you want to sync up your clock with the exchange, then refer to the following: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
