Date/Time: Thu, 13 Mar 2025 03:13:28 +0000
Tradovate/Sierra Chart setup w/ CQG login and denali data
View Count: 904
[2022-05-31 22:03:07] |
User110547 - Posts: 11 |
Hello, I have received a CQG login for my tradovate account but want to make sure I'm set up correctly. I have followed https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SetupInstructions, but when I connect I see the attached error messeages. Why is the chart not populating w/ the delayed denali data? I currently have package 10 -- will this error message go away once I add the realtime exchange data? Thank you. PS All tradovate market data subscriptins will be cancelled/not renewed. |
[2022-06-01 14:54:21] |
John - SC Support - Posts: 38621 |
We are no longer bringing CQG data into Sierra Chart for CME Group and EUREX data. Therefore, you would need to use the Denali Exchange Data Feed for this data. Refer to the Setup Instructions for the CME Group at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
