Date/Time: Thu, 13 Mar 2025 01:08:53 +0000
I have two Sierra accounts, one with AMP and one with TransAct
View Count: 344
[2022-05-31 20:14:47] |
User781967 - Posts: 18 |
Now that Sierra no longer supports TransAct, how do I run my AMP Sierra account on a second computer? Is there a way to obtain the NYSE tick and NASDAQ tick when I use the Denali data feed? Thanks.
[2022-06-01 14:09:39] |
John - SC Support - Posts: 38621 |
Since you have an account with AMP they most likely have set you up to use CQG for your order routing. Therefore, follow these instructions to connect the Sierra Chart you want to CQG: CQG Trading Platform Service: Setup Instructions Also, we have changed our packages such that in order to make any external connections you need to be on Package 10 or higher. We have gone ahead and set your account to evaluate Package 12 for the next 30 days, which will give you the external access, so you do not need to do anything else right away. Just remember to change your package to Package 11 (equivalent to Package 5) before the 30 days are finished. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
