Date/Time: Thu, 13 Mar 2025 23:53:49 +0000
file to open on startup
View Count: 759
[2022-05-31 19:26:31] |
User427561 - Posts: 217 |
kindly advidse, remind me, steps to open chart to open on startup
Date Time Of Last Edit: 2022-05-31 19:28:05
[2022-05-31 22:34:09] |
John - SC Support - Posts: 38653 |
Refer to the following: General Settings Window: Open Files On Startup (Global Settings >> General Settings >> General >> Startup) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-03 16:45:57] |
all im asking is verication on my formula. do yo dee anything wrong with the syntax? thank you
[2022-06-03 17:45:14] |
What formula are you referring to?
