Date/Time: Sun, 20 Sep 2026 00:34:59 +0000
New Minute Candle Bar didnt match to real time
View Count: 715
| [2022-05-31 19:07:20] |
| Tom_Tom - Posts: 52 |
Hello, i am using the denali data feed for Micro EMini S&P 500. If my chart is set to 1 Minute Candles, every new minute bar is build about 8-10 Seconds before the real time clock. Thanks for help! Regards Tom |
| [2022-05-31 22:27:48] |
| John - SC Support - Posts: 47939 |
It just means that the clock on your system is different from the timestamps of the data by 8-10 seconds. It is not really an issue, but if you want to set your local computer clock to be exactly the same, then refer to the following: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-01 14:09:33] |
Hi, thanks for your answer. Now i have done a manually time syncronisation in Windows 11 and its working now. Regards Tom |
