Date/Time: Thu, 13 Mar 2025 01:03:03 +0000
Volume by Price - Bid/Ask
View Count: 524
[2022-05-31 18:09:45] |
Technical - Posts: 158 |
I am working with the VBP using "Volume Bar Calculation Method" as "Diagonal - Ask Volume - Bid Volume" The histogram uses some blue bars, the meaning of which escapes me. In an effort to figure it out, I tried to toggle all the blue Subgraphs to determine what the blue bars might represent. to no avail. I can see the bid/green and ask/red bars. May I ask what the blue bars in the histogram represent? (See enclosed) |
[2022-05-31 22:24:16] |
John - SC Support - Posts: 38621 |
There are 3 items that make up a bar in the Volume by Price study. First is the blue bar that you see that is defined by the Input for Volume Bar Calculation Method. Refer to the following: Volume By Price Study: Volume Bar Calculation Method The other two items are the Bid and the Ask information as defined by Input for Bid Volume Ask Volume Coloring Method. Refer to the following: Volume By Price Study: Bid Volume and Ask Volume Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
