Date/Time: Thu, 28 Mar 2024 23:23:24 +0000
[User Discussion] - Automated Trading
View Count: 1739
[2013-04-26 19:37:55] |
User11631 - Posts: 9 |
Is there a way to create an automated strategy from a User Created drawing like a rectangle, trend / horizontal line or Fibonacci level? Thank you, Date Time Of Last Edit: 2013-04-26 19:38:29
[2013-04-26 20:20:59] |
Sort of, but this is simply outside the scope of our support. It's not something we can help with or recommend doing.
[2013-04-29 07:45:13] |
MotoMoto - Posts: 47 |
User11631 A work around is to type in the relevant values of the lines in a spreadsheet and work with those. It is not automatically updated and you have to match the values of the drawing with the spreadsheet but depending on how often you move things this is what i have ended up doing. Basically i use a spreadsheet in which i type in values, and then use other spreadsheets that read the data from that. |
