Date/Time: Wed, 09 Sep 2026 16:13:29 +0000
Saving Chart Set (Chartbooks) Up to a Disk
View Count: 719
[2022-05-31 13:24:13]
User986474 - Posts: 35
How do I save my Chartbook to a disk, to transfer to another computer for example?
[2022-05-31 21:17:34]
John - SC Support - Posts: 47815
We are not understanding what exactly you are wanting to do. Chartbooks are stored as files with the extension .cht on your local computer in the data folder which is under the main Sierra Chart installation folder.
You can copy the files from that location to move them to another computer.
Refer to the information at the following link about the various files and what is stored in each of them and where they are located relative to the main installation folder:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
