Date/Time: Wed, 12 Mar 2025 21:51:51 +0000
Data Range in days to load
View Count: 456
[2022-05-31 08:20:22] |
User824913 - Posts: 15 |
I don't really understand the behavior of this tab: Why if I set Date Range In File From to 2022-02-23 the system start to loading from 2017 as you can see in the attach file? I setup Load data limiting method (list) --> use date range and Date Range and Days to load --> 2022-02-23 Date Time Of Last Edit: 2022-05-31 08:21:12
[2022-05-31 09:45:12] |
User431178 - Posts: 613 |
Date Range In File From is not the value to set, see image.
