Date/Time: Mon, 21 Sep 2026 11:48:09 +0000
Candlesticks appear on footprint chart after opening third chart in chartbook
View Count: 760
[2022-05-31 03:12:31]
User216753 - Posts: 29
I have attached Bish-Main(2) chartbook so you can duplicate and fix this maddening problem
You will see a 15 min footprint with DOM chart, and two simple candlestick charts for the ESM22_FUT.
One is a 5 and the other a 1 min chart. You will see the footprint is as it should be with
no candlesticks on it. When you open a 3rd intraday chart, once the history is loaded, OHLC
bars will appear on the 3rd chart as well as the footprint chart. Open chart setting for 3rd chart
and change to candlesticks, They will also appear on footprint. For some odd reason, this does not
happen after opening the first two candlestick charts.
All of these charts have global graphics settings unchecked to create individual chart graphics.
I have attached pictures of Before and after adding 3rd chart.
attachmentbish-main (2).Cht - Attached On 2022-05-31 02:54:27 UTC - Size: 11.77 KB - 435 views
imageBefore adding 3rd chart.png / V - Attached On 2022-05-31 02:55:14 UTC - Size: 90.66 KB - 208 views
imageFootprint after Creating a third simple candlestick Chart.png / V - Attached On 2022-05-31 02:55:38 UTC - Size: 62.86 KB - 206 views
[2022-05-31 07:21:52]
This is not for Sierra chart to resolve. You need to resolve this on your side.
There is a study on that particular chart displaying the candlesticks. Check the studies through Analysis >>Studies and remove it.
