Date/Time: Wed, 12 Mar 2025 21:57:49 +0000
2 versions of Sierra chart on PC
View Count: 415
[2022-05-30 19:06:00] |
Mustang77 - Posts: 122 |
Hi I have 2 versions of Sierra chart on my PC, one of them was installed weeks ago and i configured it to my liking, for example i have configured the tool bar to my liking. The question is, can i just copy and paste the settings from the main sierra version to the newly installed one? that way i dont have to reconfigure everything. If the answer is yes, which folder are the settings stored on ? Thanks |
[2022-05-30 20:36:13] |
Yes this can be done. Refer to this page for complete details about what files contain what particular type of data: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
