Date/Time: Tue, 26 Nov 2024 09:29:21 +0000
Draw Volume Profile not working properly version 1130
View Count: 1138
[2014-05-01 11:45:07] |
User59042 - Posts: 22 |
Hello, I've justed update to new version 1130, but soon noticed that draw volume profile is not working the way it should. When trying to adjust it, it stays as it was and creat new profile which is blank, only seen when click into it. So it can't be modified and it creats multiple profiles when you try to change it. So only way to use it now is to draw new one, otherwise it won't work. Thanks for fixing this. |
[2014-05-01 14:31:57] |
User628 - Posts: 18 |
I upgraded to version 1130 and the cci studies separate from each other making you not be able to view the patterns. Also you can't go back to an older version. It won't recognize your chart book.
[2014-05-01 17:21:23] |
We are looking into these now.
[2014-05-02 08:33:50] |
Just updated to 1131 version and Draw Volume Profile tool still NOT working properly. Thanks for your effort.
[2014-05-02 17:52:54] |
This will be resolved in version 1132. We will be releasing this in about an hour.
[2014-05-02 17:55:00] |
Update Sierra Chart by selecting Help >> Download Prerelease. This should resolve the problem. There should not be any problem with opening a Chartbook on a prior version. Although what version did you try to go back to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
