Date/Time: Thu, 13 Mar 2025 04:17:40 +0000
Can't display and get intraday data for $DAX
View Count: 480
[2022-05-30 18:42:24]
User705132 - Posts: 5
I can't display and get intraday data for $DAX. I have only daily data without volume. Is it normal? Right now I am on trial version. Do I need any extra package to be able to get intraday dax data with volume?
[2022-05-31 17:45:38]
Up
[2022-05-31 22:05:14]
John - SC Support - Posts: 38621
Are you wanting the DAX Performance Index ($DAX) or the DAX Futures from EUREX?
What you are getting now is the DAX Performance Index, for which we only have the daily data.
If you want the DAX Futures, then you will need to use the Denali Exchange Data Feed for the EUREX data. Refer to the information at the following page, which includes Setup Instructions:
[2022-06-01 19:20:30]
Thank you!
