Date/Time: Fri, 11 Sep 2026 16:46:38 +0000
[Programming Help] - Same values repeated on all bars (should not)
View Count: 1087
[2022-05-30 17:33:52]
BenjFlame - Posts: 353
here is a calculation of delta. I know it's build-in in sierra but I will need to code it.
SCSubgraphRef SubGraph_NQ_Volume_Delta = sc.Subgraph[1];
if (sc.SetDefaults)
sc.MaintainAdditionalChartDataArrays = 1;
sc.CalculationPrecedence = LOW_PREC_LEVEL;
// Set the defaults
sc.GraphName = "INSTRUMENTS FLOW";
sc.GraphRegion = 0;
sc.ScaleRangeType = SCALE_SAMEASREGION;
SubGraph_NQ_Volume_Delta.Name = "NQ volume delta";
SubGraph_NQ_Volume_Delta.DrawStyle = DRAWSTYLE_TEXT;
SubGraph_NQ_Volume_Delta.PrimaryColor = RGB(255, 255, 255);
SubGraph_NQ_Volume_Delta.LineWidth = 12;
sc.AutoLoop = 1;
return;
float NqDelta = sc.BaseData[SC_ASKVOL][sc.Index] - sc.BaseData[SC_BIDVOL][sc.Index];
SCString NqDeltaText;
NqDeltaText.Format("%.0f", NqDelta);
SubGraph_NQ_Volume_Delta.TextDrawStyleText = NqDeltaText;
SubGraph_NQ_Volume_Delta[sc.Index] = sc.Close[sc.Index] - 1;
That code displays the delta from last bar (which is correct) but under ALL the previous bars also, instead of each bar's value under it. Where is the mistake?
[2022-05-30 17:41:32]
Answering my own question: I guess I need to store the calculation in an array instead of a float...
[2022-05-30 19:17:30]
I was wrong, it won't work even with an array:
// NQ
SCSubgraphRef SubGraph_NQ_Volume_Delta_Data = sc.Subgraph[0];
SCSubgraphRef SubGraph_NQ_Volume_Delta_Text = sc.Subgraph[1];
if (sc.SetDefaults)
// Set the defaults
sc.GraphName = "MULTI INSTRUMENTS FLOW";
sc.GraphRegion = 0;
// Graphs
SubGraph_NQ_Volume_Delta_Text.Name = "NQ delta text";
SubGraph_NQ_Volume_Delta_Text.DrawStyle = DRAWSTYLE_TEXT;
SubGraph_NQ_Volume_Delta_Text.LineWidth = 12;
SubGraph_NQ_Volume_Delta_Data.Name = "Text";
sc.AutoLoop = 1;
return;
SubGraph_NQ_Volume_Delta_Data[sc.Index] = sc.BaseData[SC_ASKVOL][sc.Index] - sc.BaseData[SC_BIDVOL][sc.Index];
NqDeltaText.Format("%.0f", SubGraph_NQ_Volume_Delta_Data[sc.Index]);
SubGraph_NQ_Volume_Delta_Text.TextDrawStyleText = NqDeltaText;
SubGraph_NQ_Volume_Delta_Text[sc.Index] = sc.Close[sc.Index] - 1;
and still display same last value under ALL bars. Why?
[2022-05-30 20:10:33]
User431178 - Posts: 905
When you use DRAWSTYLE_TEXT this means the specified text is drawn at each bar/column in the chart at the value specified in the corresponding Subgraph Data element. The actual text is specifed with sc.Subgraph[].TextDrawStyleText. The font height is specified through sc.Subgraph[].LineWidth. If sc.Subgraph[].DrawZeros is 0, and the sc.Subgraph Data element for a bar/column in the chart is set to zero, no text will be drawn.
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle
Maybe look at custom value at Y?
Date Time Of Last Edit: 2022-05-30 20:11:27
[2022-05-30 21:36:35]
Yeah, that's how they are doing it, so I guess it's the way.
