Date/Time: Wed, 12 Mar 2025 21:33:43 +0000
Broker and packages
View Count: 422
[2022-05-30 16:24:18] |
jetlag01 - Posts: 1 |
Hi there. Hope you are well. I'm coming from cfd trading and would like to start trading futures using level II data. My question is, will using one of your packages I.e. with the Denali data be sufficient? Can I just pay the package fee, deposit cash and start? Or will I have to use a different broker and then link it? Your assistance will be highly appreciated. Kind regards
[2022-05-31 10:13:15] |
First thing we recommend you do is to use our Delayed Exchange Data Feed: Delayed Exchange Data Feed And then once you are ready to begin with real-time data we will help you with that. Start though with the Delayed Exchange Data Feed. You have access to it now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
