Date/Time: Wed, 16 Sep 2026 02:43:53 +0000
[User Discussion] - CROSSFROMABOVE
View Count: 851
| [2022-05-30 13:44:59] |
| KlimKady - Posts: 4 |
I am trying to get a buy signal on a daily chart when RSI crosses the bottom line, bottom line is set at 10, from above. Can CROSSFROMABOVE be used for this? It is not a range but one line crossing another. This =CROSSFROMABOVE(ID6.SG5@3,ID6.SG7@3) did not work, ID6.SG5 is the RSI Connor line and ID6.RG7 is the bottom RSI line it crosses. Date Time Of Last Edit: 2022-05-30 14:03:18
| [2022-05-30 14:22:41] |
| Ticks - Posts: 212 |
I assume you are using a study and not a spreadsheet. CROSSFROMABOVE(ID6.SG5,ID6.SG7) You might want to read the documentation also. Study/Chart Alerts And Scanning: Alert Formula Examples Date Time Of Last Edit: 2022-05-30 14:25:40
| [2022-05-30 15:06:08] |
I am using the spreadsheet for trading, I should have mentioned that.
| [2022-05-30 16:10:00] |
Spreadsheet Systems, Alerts and Automated Trading: Creating a System or Alert Table of Contents | (Spreadsheets) You might want to invest some time in reading. https://www.sierrachart.com/index.php?page=doc/Contents.php The support board also has a search feature. https://www.sierrachart.com/SupportBoard.php?do=Search&LimitToForum=0&Query=CROSSFROMABOVE+spreadsheet&Submit_Search=Search Date Time Of Last Edit: 2022-05-30 16:17:10
| [2022-05-30 17:05:32] |
I finally got it, 2 or more points makes a line. I'm and idiot!
| [2022-05-31 02:43:49] |
| Sawtooth - Posts: 4353 |
Alert syntax is different than spreadsheet syntax for the CROSSFROMABOVE function: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#CROSSFROMABOVE_Function |
