Date/Time: Fri, 25 Sep 2026 20:12:29 +0000
WISHLIST - Variable Names for IDxx.SGyy
View Count: 784
| [2022-05-28 15:49:01] |
| User656492 - Posts: 160 |
For the wishlist: Life would be much easier if we could have a study that allows us to create variable names for other studies and subgraphs. Example: StudyName: Variable Names For Chart Name: VAH Reference: ID7.SG2 Name: VAL Reference ID7.SG3 where ID7 is Volume Area Value Lines study on same chart. It would be so much easier to read =AND(C>C[-1],C>VAH) as opposed to =AND(C>C[-1],C>ID7.SG2) Trying to navigate the 50 studies I have stacked to accomplish my goals is exponentially difficult as I add more value to my charts. |
| [2022-05-28 20:53:34] |
| JohnR - User831573 - Posts: 338 |
I think what you want is already here in ACSIL ACSIL Interface Members - sc.Subgraph Array A useful method to make it easier to work with a sc.Subgraph[] and the sc.Subgraph[].Data array is to use a C++ reference. A reference is defined with SCSubgraphRef. SCSubgraphRef is a reference to the sc.Subgraph[] type. Below is an example of defining and using a reference. Example // Make a reference to the second Subgraph and call it PlotB SCSubgraphRef PlotB = sc.Subgraph[1]; // Now the PlotB reference can be used in place of sc.Subgraph[1] // Set the value of the element in the Subgraph Data array the // current index to 10. // This is the same as sc.Subgraph[1][sc.Index] = 10.0f; PlotB[sc.Index] = 10.0f; Hope this helps. johnR |
| [2022-06-01 15:49:39] |
Really for something like this you need to move to ACSIL: Advanced Custom Study Interface and Language (ACSIL) Then you will have the ability to name Subgraph and Inputs with whatever name you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
