Date/Time: Wed, 12 Mar 2025 21:35:43 +0000
Status Bar Width in Characters
View Count: 606
[2022-05-28 02:55:53] |
58LesPaul - Posts: 429 |
I've tried changing this input anywhere from 8 to 28 and it doesn't change the width at all. I'm running 2394. Thanks |
[2022-05-28 05:54:17] |
You need to remove and add the control bar through Window >> Control Bars >> Control Bar # after changing that setting.
