Date/Time: Tue, 29 Sep 2026 17:25:56 +0000
ERROR EN CONEXION
View Count: 746
| [2022-05-27 21:51:17] |
| LUCERO R - Posts: 4 |
Hola. Hoy quería conectarme a Tenton Futures Order Routing. Seleccioné CME Futures Order Routing, pero mi firma de compensación AMP Futures no me aparecio en las opciones. Ya fue aceptada mi solicitud con el broker para utilizar el servicio de enrutamiento directo de pedidos CME de Sierra Chart. Entonces apareció el error de conexión: No hay cuentas comerciales asignadas Agradezco tu ayuda. |
| [2022-05-28 06:08:37] |
Translation: I selected CME Futures Order Routing, but my compensation firm Amp Futures did not appear in the options. My application with the broker was already accepted to use the direct route of orders CME of Sierra Chart.
Then the connection error appeared: there are no assigned commercial accounts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-28 15:21:40] |
In the case of AMP, they use CQG. For now you need to follow through the set up instructions here for CQG: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
