Date/Time: Wed, 12 Mar 2025 22:18:31 +0000
chartbooks
View Count: 438
[2022-05-27 18:30:59]
User977161 - Posts: 2
Hi, I have recently started up a free trial two days ago. I downloaded some chartbooks into sierras data folder. After, I launched sierra charts and tried to open the chartbooks. For some reason the chartbooks appeared white/blank with no data or info, same thing with my DOM chartbook. I was wondering why I can see any information. Is it because I have a free trial? Would you recommend buying package 5 and skipping the trial? what should I do to see my Information?
-thankyou
[2022-05-27 21:47:14]
John - SC Support - Posts: 38621
Maybe the symbols are not correct. Translate the symbols by selecting Edit >> Translate Symbols to Current Service. Refer to the following:
Edit Menu: Edit >> Translate Symbols To Current Service
