Date/Time: Mon, 09 Nov 2026 08:33:36 +0000
[Programming Help] - Is it possible to create shortcuts to adjust the chart range (not bar period)?
View Count: 721
[2022-05-27 16:58:28]
User8123771 - Posts: 1
For example, if viewing a daily bar period historical chart, I need an easy way to toggle between viewing the last month, last 6 months, last year, etc.
To be clear, I don't want to change the bar period, I want to adjust the range of data shown. I know I can drag on the X axis to manually scale, but it would be a lot more convenient for me to be able to add buttons in the control bar for the different ranges since i have to do this a lot.
[2022-05-27 17:46:01]
JohnR - User831573 - Posts: 340
I have not found a direct way to do this, but there are read only variables - First visible bar and last visible bar.
There are read / write calls to set the scale, but not the visible bars. Maybe SC can change these 2 variables to read/write. It may exist and I have not found it, as most things are possible in SC.
Another work around would be to use AutoHotKey and write a macro that simulates a specific # of Cntl + arrow presses to achieve what you want
Hope this helps,
JohnR
Date Time Of Last Edit: 2022-05-27 17:51:56
