Date/Time: Wed, 12 Mar 2025 21:17:21 +0000
DELAY
View Count: 473
[2022-05-27 16:13:34] |
LUCERO R - Posts: 4 |
HOLA TENGO UNA CUENTA ES DE AMP Y E INTRODUJE LOS DATOS DE CQG COMO LO DICE EN LAS INSTRUCCIONES, PERO NO ME CARGA LOS DATOS DE LAS GRAFICAS, LE CAMBIE A LA OPCION SC DATA (ALL SERVICES), PERO LAS CARGA CON UN DELAY. ME PUEDES AYUDAR? |
[2022-05-27 18:06:52] |
John - SC Support - Posts: 38621 |
From Google Translate: I HAVE AN AMP ACCOUNT AND I ENTERED THE CQG DATA AS IT SAYS IN THE INSTRUCTIONS, BUT IT DOESN'T LOAD THE GRAPHICS DATA, I CHANGE IT TO THE SC DATA (ALL SERVICES) OPTION, BUT IT LOADS THEM WITH A DELAY. CAN YOU HELP ME?
First thing is to connect your system to CQG. Follow these instructions to do so: CQG Trading Platform Service: Setup Instructions The reason why you are not getting any data is that with version 2394 we are not longer allowing data into Sierra Chart from CQG for the CME Group and EUREX. Refer to the following: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394 We recommend using our Denali Exchange Data Feed for the data. Refer to the information on the following page, which also includes Setup Instructions: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
