Date/Time: Sun, 20 Sep 2026 07:46:34 +0000
Order filled
View Count: 743
| [2022-05-27 15:50:29] |
| User575872 - Posts: 78 |
Hi, a question of understanding: How can it be that the MES order is filled at 11:20 CET (greyed out in the trade orders window), but the price is far from it at this time? Thank you for an answer and best regards Wolfgang |
| [2022-05-27 17:44:50] |
| John - SC Support - Posts: 47939 |
We can't say for sure, but in general a Sell Limit that is placed below the current price is going to fill immediately, since the higher price is a better price point. Also check the Trade Activity Tab on the Trade Activity Window and check the Order Action Source for that fill to see where it came from. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-29 10:20:27] |
Yes, ok, thanks, I probably made a mistake. But it's usually the case that a normal bracket order on the SC server side stays valid even if I turn off my PC, right?
| [2022-05-29 11:15:30] |
We see you are using CQG. Not the Sierra Chart Teton Order Routing Service. Therefore, regarding this: But it's usually the case that a normal bracket order on the SC server side stays valid even if I turn off my PC, right? Refer to:Attached Orders: Management of Attached Orders when Trading Service Supports Server Side OCO Only We do recommend using Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-29 11:15:52
| [2022-05-29 16:21:07] |
Okay, thanks for the information. I remember: I didn't activate Teton because it didn't work with my broker AMP yet.
