Date/Time: Wed, 12 Mar 2025 21:12:28 +0000
Denali Additional setup request
View Count: 551
[2022-05-27 02:02:40] |
BHowellNZ - Posts: 21 |
Hi support I have gone through the Denali set up instructions and I have not been able to get an (M) signal for any of the products I want data for to supplement my current data feed. What I am wanting to achieve - Currently have CQG data for OSX Nikkei and HKE Hang Seng data - I am wanting first and foremost EUREX data for Fixed income products and Eu equities. I cant seem to find a Denali section for EUREX or any other exchange for that matter (only CME futures options) within the symbols list The next steps say to contact support - can you please set up from your end? Kind regards Brad |
[2022-05-27 13:52:37] |
John - SC Support - Posts: 38621 |
Please go through the Setup Instructions at the following link to get the EUREX data: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-30 02:27:50] |
OK - All done What is needed to be done now to find and use the Denali feed for EUREX? |
[2022-05-31 16:05:04] |
You still need to activate the exchange for the EUREX data. You can do this at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedEUREX#Exchanges Once you have activated that exchange then the data will be coming from the Denali data feed rather than CQG for EUREX data. As you noted previously, look for the [M] after the symbol in the Chart Header to verify that you are getting the data from us. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
