Date/Time: Wed, 12 Mar 2025 21:20:01 +0000
Put Sierra on Hold for 2 months
View Count: 518
[2022-05-26 17:46:47] |
User447693 - Posts: 24 |
Hello I am off on a leave for 2 months I would like to put my account on hold for two months before it renews How can I do it? Thanks |
[2022-05-26 19:40:54] |
Refer to: Sierra Chart Purchase and License Information: Suspending Usage Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-26 21:57:31] |
also I ended up signing for a free product and I dont want it. I dont see any difference its useless can u take it out. Thanks I dont want to pay for it. Padmaja |
[2022-05-26 22:02:03] |
John - SC Support - Posts: 38621 |
What product are you referring to?
[2022-05-26 22:45:32] |
I dont know its the highest level? and also can you cancel my subscription as I dont want to pay month to month and I will re instate
[2022-05-27 13:50:13] |
You are referring to the Package 12 evaluation. We have turned that off for your account. Although it is just an evaluation for 30 days and you would not have been charged for the package, it would have just ended and you would continue with the package you had already selected. We also refunded the 1 full month of extra Usage Time that you had available. You now have Usage Time ending on June 3, 2022. After that, your account will expire. When you are ready to start again, follow the instructions at the following link to select your package: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
